After all the recent talk about these wipers, I thought I'd get me a set, initial results seem very good, the weathers set to turn sh!te so we'll see how they stand up. No noise at all (I've ALWAYS had wiper noise on my FTO's) and only one or two judders so far, we'll wait and see, otherwise I have to give them the thumbs up
EBC Greenstuff v4s
My Pagids were on the way out, they're dusty as hell so I was eagar to throw a new set in there. While I was at it, I swapped out the set of worn drilled & grooved Black Diamond disks (the grooves were pretty much worn away) for a standard set that were barely broken in (1000 kms or so - the originals I got with the car). I'm still braking in the pads but so far I can say that they bite well (at least as well as the Pagids), although the nearly new disks are probably helping in that regard (a lot less pedal travel). I've used Greenstuff v2's in the past and I thought that they were sh!te, the v4s are a vast improvement. The only bad thing that I can say about them is they're a lot dustier than I had imagined; the advertising clearly states that they're a low dust pad, but I'm not so sure
