grinding and knocking noise
Postby mnmmurphy » Thu Oct 22, 2009 9:30 pm
there is a grinding and knocking noise coming from the front passanger side wheel area when i go over speed bumps or rough ground while driving slow.i changed the anti roll bar bushings and the links seem fine.any suggestions
mnmmurphy
Re: grinding and knocking noise
Postby Myfeckin FTO » Fri Oct 23, 2009 1:11 am
mnmmurphy wrote:there is a grinding and knocking noise coming from the front passanger side wheel area when i go over speed bumps or rough ground while driving slow.i changed the anti roll bar bushings and the links seem fine.any suggestions
Get the FTO on a ramp and check the wheel bearings. Also check out your brakes - ensure a caliper is not sticking and the brakes are wearing evenly.
When were the droplinks last changes - these do seem to wear every couple of years.
Postby gt94 » Fri Oct 23, 2009 1:23 am
cv joint maybe :?:
gt94
Postby Muad_dib77 » Fri Oct 23, 2009 11:52 am
if you dont have a ramp at hand see if there is any movement in the wheel by pulling and pushing it..
Check if there is any odd wear patterns on your brakediscs - does your wheel get warm to the touch after a short spin?`If yes could be a siezed brake piston and a worn brake pad..
Check if there is a pebble stuck in the brake disc (makes a MAD racket!)
Postby mnmmurphy » Fri Oct 23, 2009 11:53 am
gt94 wrote:cv joint maybe :?:
KUST GOT THE CV JOINT CHANGED WEEKS AGO SO IT CANT BE THAT
mnmmurphy
Postby CJ » Fri Oct 23, 2009 2:45 pm
mnmmurphy wrote:KUST GOT THE CV JOINT CHANGED WEEKS AGO SO IT CANT BE THAT
Have you got under the car yet to check what the guys have suggested? Eliminate all of these items and them come back to us.
Postby mnmmurphy » Fri Oct 23, 2009 5:33 pm
thanks for the advice lads.i will be away this weekend but ill get underneath it next weekend.hopefully it is one of them
mnmmurphy
Postby karlf » Fri Oct 23, 2009 5:50 pm
Could be loose wheel nuts, sounds silly but I had it happen before. A couple of the nuts were loose and the wheel was able to move a bit. It wasn't overly loud but it could be heard in the car. Funnily enough it was only when driving slowly I heard it. Worth checking anyway especially as you've had the wheel off a couple of times, sometimes the nuts come loose themselves and need to be tightened again. (happened a cople of times to me recently)
My sis's fella had his front passenger wheel fall off and needed a new wing. Luckily there wasn't any other damage done.
karlf
