Tappet Adjusting Tool
Postby dave100 » Thu Nov 02, 2006 2:17 pm
Long shot i know but does anyone know where i can get one of these tools from as i want to reset my tappets.
dave100
Postby Myfeckin FTO » Thu Nov 02, 2006 2:19 pm
FTODIY site has a link to making your own tool for adjusting tappets - too busy to find link - do a search and it will come up no doubt.
Postby Muad_dib77 » Thu Nov 02, 2006 2:36 pm
Postby dave100 » Thu Nov 02, 2006 3:08 pm
i saw that but i dont have a welder! i was hoping some kind soul would rent me it out for a weekend :)
dave100
Postby Storm » Fri Nov 03, 2006 1:14 pm
Get a lonch reach 10mm socket from Halfrauds, or the Irish equivalent, and grind the side off it with either a grinder (Doh!) or llike I did, a stone wheel in a drill.
If you do a search on the UK FTOOC you will find it easy enough. I made mine in half an hour.
HTH
Arashi
Storm
Postby steelroe » Tue Nov 07, 2006 10:00 pm
Get a 10mm box wrench from a hardware store and cut the side off to open it up . A screwdriver will the fit down the middle and you have a tool even better than the mitsi one.
Postby dave100 » Wed Nov 08, 2006 12:24 pm
excellent tip rory! that is much handier. I will try that instead. Do i need a screwdriver with a hex on the shaft or do the tappets adjust easily?
dave100
