Three questions
Three questions
Postby Bernard » Fri Nov 23, 2007 2:01 pm
I was having a root around the car today and I found a couple of bits I'm not sure about.
What is this switch for?, I was thinking it might be there to make checking for error codes easier...
These were in the boot, am I right in thinking they're the TV areials for the back window?
I know what it says but I'm still confused :smt017
Postby Myfeckin FTO » Fri Nov 23, 2007 2:10 pm
They are the TV aerials - usually found on the rear window - I took them off my last FTO - reception is next to useless in Ireland. The switch I imagine is an override so that you can watch the TV while the FTO is moving - usually these TV systems would be configured to turn off when the car is rolling - but all usually have some kind of sneaky override switch.
Postby colm_mcm » Fri Nov 23, 2007 3:12 pm
that switch under the dash could be for anything! does pressing it do anything?
Postby Myfeckin FTO » Fri Nov 23, 2007 4:03 pm
colm_mcm wrote:that switch under the dash could be for anything! does pressing it do anything?
Could also be for the rear aftermarket fog light - I had forgotten Bernards car spent time in the UK.
Postby colm_mcm » Fri Nov 23, 2007 4:17 pm
If it's uk spec, the switch has to be illuminated. that'd be a clue!
Postby Bernard » Fri Nov 23, 2007 6:22 pm
It's not for the fog light, I have a switch for that.
I'll have a mess later and see if I can get a better idea.
Postby Daz » Sat Nov 24, 2007 1:51 am
Switch could be for an imoboliser maybe, sort of if you get car jacked give it a kick to disable the car?
Daz...
Daz
Postby colm_mcm » Sat Nov 24, 2007 2:25 am
could be for disabling the 'g' meter?
Postby Bernard » Sat Nov 24, 2007 3:09 am
colm_mcm wrote:could be for disabling the 'g' meter?
Nah, I just add water for that :wink:
Postby Bernard » Sun Nov 25, 2007 5:33 pm
OK, I checked the button out today, all it's for is to turn the parking sensors on and off :roll:
That's two out of three sorted...
Postby colm_mcm » Sun Nov 25, 2007 6:32 pm
Is it not 2 out of 3 sorted?
It that antenna for transmitting FM or receiving it?
Postby Bernard » Sun Nov 25, 2007 7:01 pm
Bernard wrote:That's two out of three sorted...
colm_mcm wrote:Is it not 2 out of 3 sorted?
Yes.
colm_mcm wrote:It that antenna for transmitting FM or receiving it?
Haven't a clue, I know I don't have an external ariel, it's integrated into the back window...
Postby colm_mcm » Sun Nov 25, 2007 7:12 pm
I don't know what happened there! thought you said "1 out of 3 sorted". really must learn to read properly!
