ftokl wrote:............
Camskill have one for the v6, I guess thats the same as the 1.8 pump.
steelroe wrote:Sound like you may have injested water through the air intake into the engine. You need to do a compression test. I dont have wiring diagrams for the 1.8 unfortunately.
ftokl wrote:Would water in the air intake/engine be serious?..
ftokl wrote:These are 'fail safe codes' meaning that the AT/ECU has gone into fail safe mode, there-by disabling ignition.
Are you getting spark? Have you check the coil etc? Is the fuel pump getting power, is it engaging? If everything checks out, I'd consider dropping in a second ECU, you should be able to get one from steelroe for reasonable money.
ftokl wrote:So I disconnected the main fuel input to the fuel rail and turned the engine, no fuel came out, nothing.
No engine diagnosis code, the light is just flashing at 1/sec. I think that indicates no errors.
Wire the pump up to a direct 12V feed to see if you get fuel. did you check before or after the fuel filter (has the latter been changed at any point?). 1hz flash frequency means all engine sensors are operating normally, I reckon your problem is something more fundemental. As I undertand it, the fuel system is pressurised, the pump will continue to operate even when no fuel is being injected into the cylinders (this keeps the system at the required pressure). Someone correct me if I'm wrong...
