Adjustable camber bolts??
Postby gary d » Thu May 07, 2009 9:24 pm
Has anyone got adjustable camber bolts fitted? Camskill recommend these are fiited when lowering a car to acheive 1 degree negative camber. How beneficial would this be to turn in, and how much does it change the stance of the car visually? Allways thought the front wheels on the fto look strange when you look down the side profile. i.e. rearwhhels are slightly raked out at bottom (negative camber) front are neutral camber 0 degrees.
99 Subaru Impreza Turbo, 95 Mitsubishi FTO gpx, 2000 Nissan Micra.
gary d
I'm addicted to my FTO
Re: Adjustable camber bolts??
Postby Bernard » Thu May 07, 2009 10:11 pm
Postby gary d » Thu May 07, 2009 10:53 pm
So is that a yes or no :lol: :smt005
gary d
Postby Bernard » Thu May 07, 2009 11:28 pm
I have them fitted, not sure if you'd notice it though (click for bigness).
Postby CJ » Fri May 08, 2009 9:29 am
gary d wrote:How beneficial would this be to turn in, and how much does it change the stance of the car visually?
No visual change, improved turn in and cornering.
Incidently, KYB shocks mated with lowering springs will give you a degree of negtive camber.
Postby gary d » Fri May 08, 2009 8:32 pm
very subtle Berno, but you can see it if you know what your lookin for. Would you agree with CJ's comment regarding improved turn in? as this would be the desired effect.
gary d
Postby gary d » Fri May 08, 2009 8:41 pm
In regards to the KYB shocks, my standard shocks are ok for the moment but would definitely consider these as and when required. Hard to imagine the fto handling improving by much as is already pretty sorted by my estimations. virtually no noticable bodyroll. would be interesting to compare a standard one against one thats sorted so to speak. hint hint Dan :lol:
gary d
Postby CJ » Mon May 11, 2009 3:10 pm
gary d wrote:Hard to imagine the fto handling improving by much as is already pretty sorted by my estimations. virtually no noticable bodyroll
I thought the same until I undertook a full suspension refit a few years ago, the difference in handling was like night and day. More info here. Thats not to day that the FTO handles badly in stock form but some components can get a bit tired after a few years.
Postby gary d » Mon May 11, 2009 3:19 pm
for sure mine is a 95. Got some new track rod ends when I ordered the Apex, kill two birds with one stone. My mate whom I bought the car from had already fitted poly bushes to the antiroll bars. I would like strutbraces. Are cusco the only ones available for cars with ABS and TC? as theyre a bit expensive imo. Can you fit a strut brace designed for a non ABS/TC car to one which has ABS/TC as the only differenc I can see in two types is an offset in the bar on ABS/TC type to clear brake fluid reservoir? hard to tell from pictures on Camskill and FTOOC.
gary d
Postby Bernard » Mon May 11, 2009 5:41 pm
gary d wrote:very subtle Berno, but you can see it if you know what your lookin for. Would you agree with CJ's comment regarding improved turn in? as this would be the desired effect.
In all honesty, I couldn't say (haven't driven that many) but mine is on Tein coilovers and has front, back & underneath braces fitted so she's pretty sorted.
You're welcome to take it for a spin at the next meet if you like.
Postby gary d » Mon May 11, 2009 6:06 pm
Very generous offer, I'll hold you to that. Coilovers are the mutts nuts! I think it would be fair to say your car is pretty sorted all over Bernard, your a hard act to follow :lol:
If I remeber correctly Laura promised me a spin in her car, when I was debating about changing to a gpvr manual or a scooby :wink: Decided on makin the most of my gpx tip considering the credit crunch an all, hence the suspension and brake upgrades :)
gary d
Postby kevinod » Mon May 11, 2009 6:34 pm
I have adjustable camber bolts on mine, and it needed the camber adjusting bolts to get the setup right after putting on Apex springs and KYB shocks as it adjusted it a bit off as CJ mentioned. HOWEVER, one of them sheared on me one day, and I've lost a bit of faith in them, so I have a set of camber-adjustable top mounts I'm going to fit (one of these days). Downside will be a slightly harder ride apparently, but up side will hopefully be spot on adjustment. I think the ones I got were HKS (from guy on ftooc).
