just had a costly morning and need some advice.
Was coming down a narrow back road this morning when a transit came round the corner in the middle of the road and I had to swerve to avoid him,and ended up smacking 2 alloys off a pothole/rock.
Now I have one puncture, which isn't to bad, but the other alloy took the brunt of the force, and the damage is as follows.
As you can see, there's a bad crack and a chunk missing.
I suppose the first question is, is this beyond repair? I've heard they can weld small alloy cracks, but this seems kinda big, plus there is actually bit missing.
If this turns out to be not possible, is it hard to buy a single alloy? I've heard its nearly as cheap to buy a full set? Typically, I'm just back from holidays so money is tight as is, so any help or advice would be greatly appreciated!
As always, thanks in advance guys,
TC
