I was wondering if any of you guys have addressed the issue of rust inside the frame. I've had a look inside the rails into which the rear crash bar fits and there is plenty of rust present. Wire brushing is out of the question since I couldn't really fit one except really close to the outside.
Two products I've found seem applicable: the Dynax S-50 wax and Eastwood Internal Frame Coating. I've read good things about both. Don't know which one would be better; or if any other solutions exist, for that matter.
Don't know if this is limited to FTO's but it seems as if behind every panel I pull is a nasty amount of rust
-Adrian.
