sensor on back of inlet manifold
Postby croagy » Mon Jun 23, 2008 4:37 pm
does contol idle in any way? its the on the inlet manifold driver side at the rear held on with 3 allen key bolts with 3 plugs on. and has the cog and screw in it. done ma timing belt so had to take it off and its idling a bit too high now. has this any affect on this?
croagy
Re: sensor on back of inlet manifold
Postby mcgon1979 » Mon Jun 23, 2008 6:38 pm
croagy wrote:does contol idle in any way? its the on the inlet manifold driver side at the rear held on with 3 allen key bolts with 3 plugs on. and has the cog and screw in it. done ma timing belt so had to take it off and its idling a bit too high now. has this any affect on this?
I would say its more likely the TB cable just needs to be adjusted...
mcgon1979
