car wont start after new front pipe!!
Postby andypandy111 » Mon Sep 03, 2007 7:35 pm
Changed the old front pipe on my mivec to a shiney new stainless steel one. Couldnt wait to start it after the old 1 being blowing for 5 months!! I turn it over and it constantly fires, but thats it! Will not start. Please help it is driving me mad!!!!!!
andypandy111
Postby Myfeckin FTO » Mon Sep 03, 2007 8:08 pm
Welcome Andy,
By front pipe do you mean the air intake pipe or the exhaust downpipe?
If air intake pipe did you check that you didn't knock anything out of line or break any wires - e.g. stepper motor or engine temperature sensor - both located under the intake pipe.
Presume you also disconnected the battery to reset ECU after you changed the pipe.
Have you checked Error codes? What code if any?
downpipe
Postby andypandy111 » Mon Sep 03, 2007 8:36 pm
Thank you. Yes it the downpipe that I have changed. And the only thing that has happened is that the 4 wires are apart [lambda sensor?]. Tried to put them back together but still does not start!
andypandy111
Re: downpipe
Postby CJ » Mon Sep 03, 2007 9:00 pm
andypandy111 wrote:And the only thing that has happened is that the 4 wires are apart [lambda sensor?]
Can you elaborate Andy? When you say that the four wires are apart, is that to say that the lambda was damaged at some point during the swap out?
Suggest you undertake a diagnostic test to see what sensors are showing up as faulty, see here:
http://www.ftowa.com/html/workshop/workshopart07.html
Postby andypandy111 » Mon Sep 03, 2007 9:05 pm
I dropped the front pipe as I disconnected it and it pulled the wires apart. I have tried every combination to re connect them but nothing happens. The car worked 100% before I changed the pipe. It does fire everytime, but will not run.
andypandy111
Postby Myfeckin FTO » Mon Sep 03, 2007 10:46 pm
andypandy111 wrote:I dropped the front pipe as I disconnected it and it pulled the wires apart. I have tried every combination to re connect them but nothing happens. The car worked 100% before I changed the pipe. It does fire everytime, but will not run.
Well theres only supposed to be 4 wires there - one of them has to be power, the other signal and the last two (black I think) are the sensors.
If you've wired them incorrectly its likely the engine will run in "safe mode". TBH you can buy a universal lamda sensor off ebay for around 20-30 Euros so you may be better off going down that road - http://cgi.ebay.ie/BN-Universal-3-Wire- ... dZViewItem
Otherwise Steelroe may have a second hand part or Ricerocket or Camskill will sell OE parts.
Postby andypandy111 » Mon Sep 03, 2007 10:53 pm
Thank you. Will the sensor not wired stop the car from running? The engine will not run at all, just fire. I have a Hyundai amica on my drive that does exactly the same thing! And a 635CSI which will not fire at all, I am an electrical nightmare. The diagnostic code item looks awesome, cant wait to try it tomorrow.
andypandy111
Postby Myfeckin FTO » Mon Sep 03, 2007 11:00 pm
andypandy111 wrote:Thank you. Will the sensor not wired stop the car from running? .
This may be the case Andy - I've never personally pulled off my lambda sensor to find out! :P
Postby gt94 » Tue Sep 04, 2007 12:47 am
gt94
