digital rpm gauge
digital rpm gauge
Postby power » Tue May 05, 2009 9:49 pm
just got my digital rpm gauge from ebay, but instructions with it are very vague! anyone shed some light on how to wire this in? is it a diy job? it also has a torque setting on it to be wired into ignition distributor, it says its not for direct ignition cars, i don't know the difference!! what is the fto?
power
Re: digital rpm gauge
Postby colm_mcm » Tue May 05, 2009 10:01 pm
direct ignition is one coil per spark plug.
Postby d_dan » Tue May 05, 2009 10:31 pm
what model is it dude?
d_dan
Postby steelroe » Tue May 05, 2009 11:26 pm
I always thought "Direct Injection" was where each cylinder had it own fuel injector, injecting fuel directly into the cylinder.
Postby steelroe » Tue May 05, 2009 11:40 pm
The FTO incorporates MPI (Multi Point Injection), where the fuel is injected into the intake tract of each cylinder.
Postby colm_mcm » Tue May 05, 2009 11:42 pm
That's all well and good, but he said "Direct ignition"
I'm presuming because tachometers use the pulses to a coil pack as a measure of engine RPM, direct ignition may present a problem?
Moved to FTO Technical
Postby steelroe » Wed May 06, 2009 12:02 am
Regardless of what system it uses the rpm is relative to the ignition spark. Post up details of the unit including pic.
Normally you connect the pickup wire to the ignition lead of cylinder 1 and programme the unit for the "number of cylinders" i.e. the FTO has 6
Postby power » Wed May 06, 2009 7:37 pm
power
