Squeaking clutch pedal
Postby Neil » Thu Dec 08, 2005 4:32 pm
Starting squeaking about a week ago, usually as I release it.
How can I stop this? Is it just a case of throwing a bit of oil somewhere or other or could this be indicative of a problem somewhere?
Its driving me bananas hearing it at every stop/start/gear change!
Neil
Postby kevinod » Thu Dec 08, 2005 4:45 pm
:lol: mine got noisy for a while, but before I got around to oiling it it stopped (or did I just get used to it? :? hmmm).
Postby Myfeckin FTO » Thu Dec 08, 2005 7:18 pm
Happened me before I changed my clutch.
While doing clutch change - I got my mechanic to oil the "selecta" lever coming out of the top of the gearbox - its sits in a rubber boot and gets squeeky when not lubricated.
Postby mark » Fri Dec 09, 2005 7:50 pm
I get this problem also. Initially it feels like it's inside the cabin but I think it's mainly the 'selecta' thingy rubbing off the rubber housing. A bit of grease can do the trick but not for long!
mark
Postby mcgon1979 » Tue Apr 03, 2007 8:57 pm
mark wrote:I get this problem also. Initially it feels like it's inside the cabin but I think it's mainly the 'selecta' thingy rubbing off the rubber housing. A bit of grease can do the trick but not for long!
is this doable from the engine bay? cheers. squeak squeak
mcgon1979
Postby mark » Wed Apr 04, 2007 10:32 am
Yep, just look for the clutch rubber housing that goes into the gearbox at right side of engine. Truthfully, it may not sort it out. I think it's mainly down to climate changes etc as I hav'nt had this squeak for a while now. :?:
mark
Postby mcgon1979 » Wed Apr 04, 2007 12:04 pm
sweet. thanks mark. Sure I'll give it a go. not particularly annoying and you wouldn't really hear it with car running anyway. cheers
mcgon1979
