After posting on the FTOOC about this was told to get in touch with Mr Bishi very nice guy that he is replied in no time from the sound of it does not seem such a dawnting prospect here is what he says............................................
OK Dude,a fairly easy job this.
First,make sure you've let out all the gas (assuming you have any left in)
Then you can just start unbolting everything you see!! The condenser will come out after you've removed the radiator,then you can unbolt all the engine bay pipework. You can buy a shorter belt from
www.camskill.co.uk for when you've removed the compressor.
Next,to the hardest bit,the evaporater! That's located behind the glovebox and there's a guide
http://www.hostilesmoker.com/ in the 'garage' section. When you've removed the evaporater you'll need to replace its plastic housing and the electrical component that's attached to it (you'll see what i mean when you get it off)This allows your normal fans and stuff to still work.
And as far as i remember,thats about it!!
Good luck,Si
Will be attempting this before Xmas will let yous know how i get on
