location of Mivec light wire?
Postby Mogli » Tue Oct 11, 2011 11:42 pm
Hi at all,
i have used the search but dont find about the "MivecWire".
does someone know were can i find them?
i removed the watch and place a Mitsubishi decal there. it shines in the same colour like the interior lights. i want to place a brighter led in red in there, when the mivec kicks in its shine in red:)
in my old prelude/crx/s2000 there was a little "metalCan" in the engine bay. it gives a ground signal when the vtec starts. Have the FTO the same "trigger"
thx
Mogli
Mogli
Re: location of Mivec light wire?
Postby optical illusion » Wed Oct 12, 2011 9:07 pm
What???
*Text edited*. There is no wires or no need for wires.
[Please keep it clean guys, everyone enjoys a bit of craic and banter but bear in mind potential audiences when posting please]
Dragonheart.
Postby Sebastian » Wed Oct 12, 2011 9:36 pm
there is no visual light on your dash to show that the mivec is on apart the rev meter.
Mivec engages at 55oo rpm
Postby d_dan » Wed Oct 12, 2011 9:57 pm
Tap into the mivec oil control valve wire from the ecu.
highlighted as 35 & 36 in this pinout
d_dan
Postby Mogli » Thu Oct 13, 2011 12:10 am
hey guys, It is only for fun:-)
Thanks dan:)
Maybe do you know if it gives ground or + signal?
Mogli
Postby d_dan » Thu Oct 13, 2011 11:09 am
im not 100% sure but id say its a signal as they activate the mivec solenoid's
d_dan
Postby richardc9052 » Sat Nov 05, 2011 9:30 pm
This is what you want to do?
This is it done to a toyota with vvtli
http://youtu.be/aQamT66EAxI From Youtube.com
Cos they are "GORGEOUS" - StewyD32
richardc9052
