I went out yesterday and changed my front brake pads and when i took off the tire it had a lot of wear on the inside that could not be seen without removal,i checked the back tires while i was at it and they are almost identical in wear. I'm thinking the problem is with camber adjustment, i forgot to check for the camber bolts until after i was finished
Can i just replace them (if they are in place) with standard bolts for a gpVr/gpx and be fine or do i need to do more to the rear/front or vice versa.I also dont know if the standard springs are on the car still or they were swapped out at sometime if this matters.
i know its not much to go on but any advice is welcome. Doing the rear pads Saturday so will take some pics then if its fine.
