rsg wrote:Hate to hijack your post, but what kind of power losses could you expect if your lambda stuffs out, CJ?
rsg wrote:I'm clueless and if I don't find anyone with a MUT tester I'm pretty sure I will struggle for ages to find the problem.
rsg wrote:Ok, I've done the diagnosis, had a bit of a problem but then I found it wasn't earthing properly. Anyways the error code was 12, meaning that the Air flow sensor is screwed!
Now is the Airflow Sensor the one connected to the air pipe just after the air filter or what? If this is, then how come the car still stalls when I disconnected and it won't idle?
Anyways, now I know for a fact that that mechanic was talking shi* for f*** sake, because the lambda is showing no error codes! At least he didn't screw me over in any way with money...
Now if this sensor doesn't sort out the power problem, then it'll have to be timing or otherwise I have no Idea.
Comments anyone?
raf
rsg wrote:Anyone know what car's might have the same air flow meter just in case or where I could get one?
