steering fluid cooler pipe
Postby cliff0001 » Tue Mar 22, 2005 9:47 am
can i get one of these anywhere mine has a leak or can i slide a sleeve over it , i am not sure if the pressure it great there somehow i think i can get away with sleeving it for a while of i am unable to attend work 30 miles away lol
cliff0001
Postby CJ » Tue Mar 22, 2005 10:19 am
Cliff, FYI, the p/n for the p/s cooler pipe is MR131458, unless you can get one from a scrap yard, you may have to buy direct off Mitsubishi.
Re: steering fluid cooler pipe
Postby Myfeckin FTO » Tue Mar 22, 2005 10:37 am
cliff0001 wrote:can i get one of these anywhere mine has a leak or can i slide a sleeve over it , i am not sure if the pressure it great there somehow i think i can get away with sleeving it for a while of i am unable to attend work 30 miles away lol
I remember seeing these on www.camskill.co.uk just a short while ago - weren't exactly cheap though - I had a similar problem but found it to be a leak at a seal on the end of the pipe so no big expense there.
Give Mike a call in Camskill - I'd say he has one lying around.
Postby Myfeckin FTO » Tue Mar 22, 2005 10:40 am
BTW - Clifford - Where are you from?
What model do you drive - how long have you had car etc
Postby CJ » Wed Mar 23, 2005 9:40 pm
Cliff, theres a cooling pipe on ebay at the moment, you might pick it up cheaply if you play your cards right:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 20335&rd=1
