coming home just after leaving bernards yesterday I started hearing some sort of light clunk. ((hit a big pot hole on the way down) so thought it was a buckled alloy.
Pulled in and couldnt notice anything.
The further i drove the worse it began to get. THen started thinking had the wheel bearing went?
By the time i got to nenagh it was terrable so plodded along slowly.
By the time I was nearly home i couldnt drive anymore it was gettng beond a joke. (on the off chance that it was a buckled) i changed to the spair wheel.
When to my horror I found that all the wheel bolts had rung and that the studs had nothing to grip but a few threads at the end and the clunking noise was the wheel vibrating. I was lucky to give up when i did and that i was taking it handy because i recon the wheel would have came off before i got home.
So the cars up on jack at my other halfs house with the spacers off as i try get my hands on a 5 stud wheel hub so i can actually put the wheel abck on.
Might have some good news for you, the studs themselves are actually seperate to the hub that holds them all together, so you might be able to just get 5 studs. The studs themselves should just pop out of the hub if you hit them with a hammer from the front.
Bad luck though still, but at least you were wise and pulled in, sounds like it could've been a lot worse!
Dan I agree with colm here. you seemed to have got everything done really quick. As a rule I would always check every think twice, it can be very easy to overlook something. Did you tighten the studs when the wheel was back on the ground?
colm_mcm wrote:the stud holes of a loose wheel rubbing against the threads on the bolts?
I had a similar noise about a month a go and was not driving it for a couple of days until I had chance to look at it. Because I thiught it was a damaged pad I ordered mintex pads to replace the origonals.. When I went to change the pads, I found a few slightly loose wheel nuts!
