Auto folding mirrors..
Postby TopCat » Mon Nov 24, 2008 12:48 am
Anyone ever spot this guide before? ...
http://www.vikash.info/fto/auto_mirror/
Went at it at the weekend, and its such a neat little trick. Coming back to the car, beep beep, and mirrors fold out too, don't think it'll ever grow old. :D
For some reason though, mine only works when I open the car. i.e. they don't fold up when I lock the car. But to be honest, its actually grand that way, you can choose where the mirrors are folded when you park up.
TopCat
Postby steelroe » Mon Nov 24, 2008 10:47 am
Tom,
They should go up and down aswell if you use the key or press the lock inside. Must be something funny with your wiring.
Postby TopCat » Mon Nov 24, 2008 10:52 am
steelroe wrote:...They should go up and down aswell if you use the key or press the lock inside. Must be something funny with your wiring.
Oh yeah? Crap, mine never did that. The only way they operated before was by using the switch. :(
TopCat
Postby kevinod » Mon Nov 24, 2008 11:50 am
Not as standard, I think Steelroe means when wired up to do it they should operate with the locks as part of the central locking.
Postby TopCat » Mon Nov 24, 2008 11:59 am
Oh right. Yeah, mine (now) will fold down by the central locking, ie RCL, by key, or by the internal lock. I think they should fold up by the central locking, but mine don't. As i said, I'm happy enough with this setup though. :)
TopCat
Postby Myfeckin FTO » Mon Nov 24, 2008 4:14 pm
TopCat wrote:Oh right. Yeah, mine (now) will fold down by the central locking, ie RCL, by key, or by the internal lock. I think they should fold up by the central locking, but mine don't. As i said, I'm happy enough with this setup though. :)
Worked fine when I had this FTO! :?
Postby TopCat » Mon Nov 24, 2008 4:50 pm
Just thinking, did you have an alarm fitted on the car when you had it?
I think the polish lad said he had one fitted, so maybe they messed with the mirror switch when fitting that. :?:
TopCat
Postby Myfeckin FTO » Mon Nov 24, 2008 5:22 pm
TopCat wrote:Just thinking, did you have an alarm fitted on the car when you had it? ............
I had two alarms - And here they are! :lol:
Nah - never fitted an alarm and not just for weight saving either - you have seen where I live! Not one recorded case of a car ever having been broken into in my area - Its just too far for scumbags to travel to without taking the rotties into account. :wink:
Postby Sebastian » Mon Nov 24, 2008 8:56 pm
how long did it take you to finish it ?
Postby TopCat » Mon Nov 24, 2008 9:06 pm
I bought the relays during the week (by the way, 5-pin ones are more common, and work fine for the job) and wired them one evening in the house, half hour job really. Then fitted the system at the weekend, another half hour or a little more. The central locking wires are a little more difficult to get at than you might imagine looking at the photos (its just a bit tricky connecting the wires), but other than than, there's nothing really hard about doing it.
TopCat
Postby steelroe » Mon Nov 24, 2008 9:45 pm
Tom
What type of connectos did you use. Maybe one is not making contact properly.
Regardless if you have alarm or not it should work. You are wiring directly into the central locking control unit and the mirror control unit.
When you lock the car they close but they are not opening when you unlock, is this right.
Postby TopCat » Mon Nov 24, 2008 10:13 pm
steelroe wrote:When you lock the car they close but they are not opening when you unlock, is this right.
Nope, the opposite way around. When I lock the car nothing happens. But, if I manually press the mirror button to close them, then lock the car, when I come back, the mirrors do work along with the central locking.
Can't remember the name of them, but I used those connector where you push the two wires into a small metal plate, and a plastic clip holds them in place. I removed a bit of the plastic on the wire before hand too to get a good connection.
Wait, here is a pic of the connector, "Snap-Lock Automotive Cable Connectors" according to Maplin. :)
TopCat
Postby steelroe » Tue Nov 25, 2008 12:31 am
You deffo have a problem with wire contact or you used the wrong wire for the closing. Give all the connector a good squeeze again with a pliers. You are 99% there. Those connectors can be a female dog sometimes.
Postby TopCat » Tue Nov 25, 2008 12:47 am
Thanks Rory.
I did bare the wires to try and get a better contact, but I'll give them a check again to make sure. When you point out the fact that it is a direct connection between the CL and the mirror switch, there's no reason it shouldn't work.
Oh, quick question. For the connection to the mirror switch, you pull off a tab that reveals a load of pins, 2 of which you connect into. Its almost as if they are there for easy modding. Anyone know what their purpose is or what the rest of them do?
TopCat
Re: Auto folding mirrors..
Postby ianfl » Fri Aug 28, 2009 8:49 pm
hey guys i have relays and all set up but have different switch to one in diagram (mine has black block)any idea where i connect my two signal wires to cheers
ianfl
Postby optical illusion » Sat Aug 29, 2009 12:00 am
One of the ghey features of having a GPvR... :(
Postby gt94 » Sat Aug 29, 2009 12:07 am
Am seriously thinking of getting folding mirriors for mine miss them since the gpx went :(
gt94
Postby optical illusion » Sat Aug 29, 2009 11:39 pm
It's a pain isn't it? Ah well, I have LSD (which came in handy at Phoenix Park) so naaaa naaaa :lol:
