FS: Brembo 4 Pot Calipers & Disc's
Postby Kruizer » Mon Jan 07, 2008 7:46 pm
Drilled Disc's 325mm
Braided Lines
Box of new Ferodo pads
Came off a Golf 5 x 100
Price : E750 ono
Contact Brendan on 087-6663685
Kruizer
Postby CJ » Tue Jan 08, 2008 9:47 am
Brendan, what size are the discs?
In case theres any confusion, I'd like to point out that the FTO PCD is 5 x 114.3
Postby Myfeckin FTO » Tue Jan 08, 2008 10:54 am
CJ wrote:Brendan, what size are the discs?
He mentions they are 325mm discs - so you'd need a nicely offset set of 17's to clear the calipers and discs.
The PCD of the hub these were designed for looks to be able to accomodate both 4x100 and 5x100 hubs. Hence I doubt the discs would be suitable for the FTO's 114.3 PCD.
However I believe that the calipers could be made fit as Bernard already has the same caliper set-up from a Leon Cupra on his FTO - though obviously married to different discs.
Postby Bernard » Tue Jan 08, 2008 11:21 am
Myfeckin FTO wrote:However I believe that the calipers could be made fit as Bernard already has the same caliper set-up from a Leon Cupra on his FTO - though obviously married to different discs.
I'm nearly sure my discs are 316mm and there isn't a whole pile of room left.
I can't see 325mm discs fitting an FTO, even with 17s, 18s maybe...
Postby Myfeckin FTO » Tue Jan 08, 2008 11:35 am
325mm is on the limit of what will fit in a 17inch rim - it will really depend on rim design & offset as well as caliper size/fitment.
Postby Kruizer » Thu Jan 10, 2008 4:42 am
I'll check the pcd on the dic's but i'd say there's a second 5 x *** setting with one common hold so to speak. However if someone was interested I could get you disc's and have them fitted for ya.
Kruizer
Postby Kruizer » Tue Jan 15, 2008 1:23 pm
Bump.... Still for Sale !
Kruizer
Return to For Sale
