WANTED - Front fog light switch
Postby Temeeo » Sat Feb 22, 2014 2:05 pm
Hi all,
I'm looking for a front fog light switch. Or is it false economy to get older / previously used item?
99 Mitsubishi FTO GX Manual in Passion Red
Temeeo
Re: WANTED - Front fog light switch
Postby Sebastian » Sat Feb 22, 2014 2:42 pm
http://www.camskill.co.uk/m3b0s248p5857 ... _DE2A_DE3A
PRICEY :(
I remember fitting an aftermarket( much cheaper) switch to one of my cars so it can be done
Postby Temeeo » Sat Feb 22, 2014 2:58 pm
That was a first place where I looked and got a bit of a shock. :)
Will probably have to go down that road, but if I also implement the "Front fog-light switch fix" it should be the first time and the last time I'm going to need to buy one.
Temeeo
Postby brccrx » Sat Feb 22, 2014 7:55 pm
Should have a second hand one fully working unit if thats any good?
brccrx
FTO is my new religion
Postby Temeeo » Sat Feb 22, 2014 10:14 pm
pm sent.
Temeeo
Postby Temeeo » Sat Mar 01, 2014 12:07 pm
Part sourced from brccrx, looks brand new, thanks again! :wink:
My fog lights are still not working though, I was silly/lazy and never bothered taking the old one out until yesterday, when I discovered that the block connector is burnt/melted too... :oops:
Went to the nearest auto electrician I know (Blanchardstown Auto Electrics) looking for the connector, and was told that they are part of the wiring loom. So I'm on the hunt again.
Temeeo
Postby brccrx » Sat Mar 01, 2014 6:58 pm
Some damage there!
brccrx
Postby Temeeo » Sat Mar 01, 2014 8:59 pm
Some damage there!
Yeah! :shock:
Would you know are these the same on all Mitsis from the 90s? Or is it FTO specific? Would your old GPX that's being broken for parts have one?
Temeeo
Postby brccrx » Sat Mar 01, 2014 11:48 pm
It has it for sure and it should be good, the fog lights were working on it!
brccrx
Postby akkakkman » Thu Mar 20, 2014 10:21 pm
that connector is prone to burning because the fogs are wired direct and should really be going to a relay.
there is a thread on the fix here. it will only burn out the switch again if u dont put in your own relay.
thread http://www.fto-ireland.com/forum/viewtopic.php?f=11&t=8078&p=57830&hilit=front+fog+relay#p57830
akkakkman
Postby Kace » Tue Sep 16, 2014 8:48 pm
Anyone else got another one of these around?
Mine has already been replaced some years ago and I have also done the relay job but it seems to be shot again.
Postby brccrx » Fri Sep 19, 2014 8:11 pm
You might be best converting the fog light switch to mirage/lancer/colt one, ive that done since a while and not even have relay, seems very different quality from the fto one!
brccrx
Return to For Sale
