Was looking at ways to spruce up my interior, have the red recaros, have white dials, the usual stuff, so I got some bits, thanks to Seb and Steelroe, and was going to spray them white, but then I wanted to do something different, something I havent seen on an FTO yet, so I bought some kevlar off e-bay, and got me some resin, and set to work.
After a lot of research, and careful planning with each piece as in setting out and how to go about getting the best result with the least mess and least mistakes, so far I've got a nice bit on. Nothing is totally finished, but I'm going to start this, guide if you want to call it, in the meantime anyway and regularly update it for anyone who might want to do something with kevlar or CF in the future.
So here we go;
First off I decided the bits I was going doing, and started to gather them together. (Below is what I got so far, there will be more to be done in time).
Picture of the cloth;
First I cut the cloth to an approximate shape for each piece, and then set about sticking the cloth to the relative pieces, and let it dry before trimming and the first coat of resin;
The vents for the aircon and heating;
The door handle surrounds;
The gear level surround;
The lower centre console;
Needed to make sure I understood the workings of resin then, so did a test piece, used the mitsi badge for the front bumper. Below is a pic of the 3 stages, one in each diamond of the badge, the blank piece, the cloth without resin, and the finshed product in the upper diamond;
I was happy with the result so I proceeded with the smaller parts so as not to rush into the major parts straight away in case I made a hash of it.
A light coat od resin was applied to start off with. Some of the items below with first coats on;
Gear level surround;
Lower centre console;
Gauges hood over speedometer;
Hood has to be done in 2 parts, tricky stuff. Also I found that after sticking the cloth down the edges wouldnt stick as the cloth wasnt flexible enough, so I used superglue to fix them down.
The next step for me is once the first coat of resin has dried, I'm going to trim back and tidy up the cloth some more, and apply more coats. After that its sanding and a laquer to finish.
So far I've only trimmed back one of the vents, yet to apply a second coat of resin though.
The trimmed vent;
My main concern is doing the upper centre console, the shape of it doesnt help, it looks like a 2 stage item as well but I still havent solved how I'm going to address it. But so far things have gone well for me.
As I said, I'll be updating this as I go with the progress anyway.
