ZiNTiS wrote:Thanks for your fast reply guys
i have HKS exhaust system on it and the HKS air filter
on the dyno they want 350 Euro for setting on the system its that normal price ?![]()
if i will disconnect it it will damage my car ?
and when i start my car it turns off every time i have to press the gas pedal to keep it on until it warms
i think the problem comes from the FIELD Boxer Vtec / Mivec & Fuel controller
goz_83 wrote:Remove the controller if you can. When you start the car, where does the rev needle sit? Sometimes all you need to do is make a slight adjustment to the mixture. There is a little cross head valve at the top right hand corner of the plenum. Start the engine and adjust this until the needle is sitting at 800-900rpm. Sometimes it's adjusted too low and the engine needs to be running for a while before it runs smoothly.
brccrx wrote:Aidan, do You think that when U trigger the Mivec ground point manually ECU doesn't trigger Mivec maps? I think It does as most of the functions on the car is controlled by applying the ground by the ECU (Unless its a sensor then its rather 5V signal send trough it). Why would Mivec solenoids control and Mivec maps been separated to two different trigger signals lol.
mivecrx wrote:brccrx wrote:Aidan, do You think that when U trigger the Mivec ground point manually ECU doesn't trigger Mivec maps? I think It does as most of the functions on the car is controlled by applying the ground by the ECU (Unless its a sensor then its rather 5V signal send trough it). Why would Mivec solenoids control and Mivec maps been separated to two different trigger signals lol.
When you trigger it manually the mivec maps will engage with the solenoids. So you think that if you change the crossover point that the mivec map will activate and the timing and fueling will be right?
It's a bad idea to change the crossover point without having a way of correcting the ignition timing and fuel, neo or field controller can't do both. Really it can only change the afr.
ZiNTiS wrote:i will leave that controller as it is and i have to learn how fuel mapping works.
i adjusted the rpm from the engine and the controller changed it again :/
before i adjust the rpm i started the car and it was in 1000-1200rpm for cold start i thought the problem solved it self![]()
but later when i started it up again it turned off again
i have to change settings on fuel mapping to get higher rpm ?
brccrx wrote:
Yes, i think thats the case with Mivec, ive no idea how Honda did it on Vtecs as the solenoid is controlled by positive not by the ground![]()
Think of it this way: the cams has to switch over and the maps (ignition and fuel maps) has to kick in same time, its not the case that the maps trigger the solenoid if ya get me. It has to be one control point to avoid damage in case if the Mivec worked and ECU didnt swith to Mivec maps.
mivecrx wrote:Them ignition and fuel maps are for 5500rpm to 8500rpm when the solenoid is ground, any change and the car needs to be mapped(ignition and fuel). You think if you permanently had the solenoid ground then the car would switch over to mivec maps and run perfect from 0rpm to 8500rpm?
mivecrx wrote:I can't believe you think that a zr Ecu will run an rs engine with no problem, that's crazy. I had a zr before that had rs cams fitted and still using zr ecu, you should have seen the damage done to that engine. Zero compression due to melted piston(running lean).
mivecrx wrote:Yes all ecus will self adjust to the slightest degree but not to auto map itself when you change the crossover point lol. That will do more bad than good, even a fuel controller like a neo isn't all that great as it can only map in blocks of 8( 0-8000rpm) unlike a fully adjustable ecu.
