rev count problems
rev count problems
Postby kira34 » Sun May 13, 2012 12:51 pm
Hi i own a fto gpx i have recently just had the head gaskets changed, but since then my rev cound has been playing up, it will work fine under normal driving conditions but if i put my foot down fast (or even if i dont) and i get to 5000rpm the rev counr starts bouncing rapidly up and down untill i release it
I have looked online and according to what i have seen i think the idle control valve or sensor that just needs cleaning, so is there any idea on where i can locate it ? And do you have any pictures
i would also like to poit out that i dont loose power or anything thanks
kira34
Re: rev count problems
Postby Gerry » Sun May 13, 2012 1:36 pm
Have seen this issue a few times and in all cases it turned out to be the IFS
Ignition Failure Sensor
Gerry
Have you seen my FTO tattoo?
