Mustang wrote:Kev,
If you havn't already I suggest you remove the rear seats yourself to familiarise yourself with the set up.
You would likely need to modify the support anchor of the upright foam panel (this is assuming you leave the seating panel in place) because otherwise the seating panel will fowl the movement of the upright panel. Then as CJ said you would only need devise a lock and unlock mechanism.
Really it all comes down to; do you want to be able to move just the upright foam panel, or both the upright and seating panels?
Mustang
Haven't fully thought it through yet, just something I've been thinking about and said I'd post a message and see if anyone had done it before.
Taking off the rear seats would be a good way to check it out alright, I've removed the bottom seats when putting in the cabling for my cd changer but just reached under the upright to pass the cable through. Thanks for the 'how-to' though, that'll come in handy.
What I had in mind was to just lean the back or upright part forward, so simple hinge and catch setup. Hinges at each side at the bottom of the upright, and a catch at each side at the top of the upright. I guess if the upright leaning forward gets fouled on the bottom part I could just take the bottom up, just 2 clips as you say.
I'll get a better idea if I take off the upright part and see what happens if its just leaned forward hinged from the bottom, whether it would help much to remove the bottom part, etc. I guess. Last thing I want to do though is introduce a rattle, so whatever I do will have to be fairly tight and tidy.
Kev.
