new alloys
new alloys
Postby paul2508 » Tue Apr 01, 2008 7:42 pm
got a set of new alloys . only problem is they dont match up to the studs they are a fraction out. do i need spacers. if so where is the best place. thanks
paul2508
FTO-Ireland rules my world
Postby colm_mcm » Tue Apr 01, 2008 7:52 pm
sounds like you need "wobbly bolts" too.
what car are wheels off?
Postby paul2508 » Tue Apr 01, 2008 8:42 pm
colm_mcm wrote:sounds like you need "wobbly bolts" too.
an impreza. multi spoke. what are wobbly bolts
paul2508
Postby colm_mcm » Tue Apr 01, 2008 8:55 pm
http://uk.youtube.com/watch?v=adWfw2a-U6M
aren't Impreza wheels 5*100 PCD, FTO is 5*114. that's way too much of a difference.
Newer WRX's are 5*114 too, but the offset and centre bore are prob different.
Are they Subaru or aftermarket alloys?
Postby paul2508 » Tue Apr 01, 2008 8:59 pm
colm_mcm wrote:http://uk.youtube.com/watch?v=adWfw2a-U6M
no way so wat will i do. justsell them on. i got them for nothing
paul2508
Postby colm_mcm » Tue Apr 01, 2008 9:03 pm
just saw newer WRX's have a different stud pattern that's very close to the FTO.
check the centre bore and offset figures.
I reckon the wobbly bolts could solve the slight differences in PCD. as long as you have leeway in the wheels for the bolts to fit proplerly.
EDIT: Jaysus, just forgot the FTO uses nuts and not bolts.
I've never seen wobbly nuts (ooh-er!) they're probably available though.
Postby paul2508 » Tue Apr 01, 2008 9:32 pm
colm_mcm wrote:just saw newer WRX's have a different stud pattern that's very close to the FTO.
cheers man . sorry its not an impreza its a lagacy. doubt it makes a differerence
paul2508
Postby colm_mcm » Tue Apr 01, 2008 9:42 pm
do you know what year/spec the Legacy is? do the wheels actually sit on the bolts? are they original Subaru items?
Postby paul2508 » Tue Apr 01, 2008 9:48 pm
colm_mcm wrote:do you know what year/spec the Legacy is? do the wheels actually sit on the bolts? are they original Subaru items?
they are not the originla wheels off the legacy. its 1 99 gtb
paul2508
Postby colm_mcm » Tue Apr 01, 2008 10:08 pm
OK, here's a guy with a Legacy GTB selling alloys for an STI that is 114mm pcd. he's selling them cos they don't fit his Legacy.
http://www.uklegacy.com/forums/index.ph ... &pid=90112
On that basis, I'd guess that the GTB is 5*100mm and not 5*114?
Do the wheels actually sit on the FTO hubs?
Postby paul2508 » Thu Apr 03, 2008 8:27 pm
colm_mcm wrote:OK, here's a guy with a Legacy GTB selling alloys for an STI that is 114mm pcd. he's selling them cos they don't fit his Legacy.
no they dont match up to the studs if youknow wat i mean
paul2508
Postby colm_mcm » Thu Apr 03, 2008 11:14 pm
you're fooked so. happily, 5*100 is a very common size, so selling them on won't be too difficult.
Postby paul2508 » Thu Apr 03, 2008 11:45 pm
colm_mcm wrote:you're fooked so. happily, 5*100 is a very common size, so selling them on won't be too difficult.
col man. sso when im buying alloys wat do i have to know?
paul2508
Postby colm_mcm » Fri Apr 04, 2008 12:06 am
stud pattern is 5*114.3mm
offset is 37/38mm
centre bore is 67.1mm
Postby paul2508 » Fri Apr 04, 2008 12:09 am
colm_mcm wrote:stud pattern is 5*114.3mm
offset is 37/38mm
cheers man thanks for your help :smt023
paul2508
Postby colm_mcm » Fri Apr 04, 2008 12:12 am
no bother.
second hand wheels generally won't fit unless they're off an FTO. even if the stud pattern is close, the offset would prob be off and the centre bore would require adaptor rings, which all-in-all is a pain in the proverbials.
