Diagnostic Code Query
Postby steelroe » Tue Aug 19, 2008 9:05 am
We know that the diagnostic codes for the engine can be extracted using the earthing procedure here http://www.ftowa.com/html/workshop/workshopart07.html
But this only extract engine fault codes. So how do you extract the Automatic transmission codes. Does the above procedure also extract the trannny codes vis the "N" loght flashing.
Todays mission is to figure this one out. Or does anyone already know??
yes it works
Postby kona » Tue Aug 19, 2008 11:11 am
i have used it to get an error code for the input shaft speed sensor.
cant find the file for the meaning of all the error codes maybe
someone else here can help you with it
kona
Postby steelroe » Tue Aug 19, 2008 11:43 am
I should have read a bit more before I posted this.
Once you ground terminal 1 of the diagnostic connector, codes are flashed for the relevant ecu. i.e
Engine Codes are flashed via the engine management light.
ABS faults are flashed throught the ABS indicator.
TCL are felashed through the TCL indicator.
Automatic Tranny is flashed through the "N" light. (Note the gear lever has to be in the "P" position to flash codes from the AT ecu.
Postby Bernard » Tue Aug 19, 2008 4:42 pm
Could something be rigged so you could just flick a switch to start a diagnostic?
It'd be easier than having to unscrew panels and ground wires...
Postby steelroe » Tue Aug 19, 2008 5:10 pm
I have already done this with a very smal toggle switch. Much easier that way alright.
Postby Bernard » Tue Aug 19, 2008 5:14 pm
I thought mine had it, turns out it was just a switch for the parking sensors...
Postby steelroe » Tue Aug 19, 2008 5:34 pm
you can use that switch if you want
Postby kona » Tue Aug 19, 2008 11:23 pm
i would ground the wire to the brake pedal
kona
Postby CJ » Wed Aug 20, 2008 9:12 am
kona wrote:i would ground the wire to the brake pedal
Theres closer grounding points than the brake pedal (unless you wanted to use the brake a switch in some some mad sort of way!).
