work has begun
work has begun
Postby Daz » Mon May 30, 2016 11:31 pm
Well work started in earnest this wknd. I'm not going to lie i ain't doing all the work (like i would of done back in the days) hell i'm not even doing most of it. As it is one of the lads i work with is an ex mechanic and he'll be doing most of the work. Reason being i'll have my kids in the car and i want it to be done perfect.....
Anyway before we started i gave it thd once over and looked at the brakes... discs rusted ta f**k, and figured they'd be seized, So decided to order all new discs drilled and groved front and back mintex shoes all round and new calipers all round... shouldn't of bovered thou...thru car up on stands this wknd and cus car parked in gear and blocks on the wheels... a small bit of force and all discs moved and brakes still worked...so could just get away with new pads... but have everything bought now and everything bar rear calipers have arrived. So will probably fit all new gear.
And so onto the rust hunt. Bumpers off all looking good there but could do with some new front arch liners but unable to find any for sale as yet. My mates been all under the car with a hammer all looking sound so far but the rear arches is a different matter. There are plates covering the ends of the drop rails these plates make up part of the wheel arch its the plate with the rubber bung in it... which the manufactures sometime use to fill the drop rails with wax. Now mine are starting to rust around the bung and a tap with the hammer caved one in but the drop rails look ok from underneath but sideskirts gonna have to come off to make fully sure. Hopefully get away with cutting plate away and welding a new one in... issue is wheel arch not undersealed like underneath so probably why it got dammage.. will get underseal treatment this time round thou. And going to get wire attachment for drill and clean whole under car to be fully sure no rust thru any stone chip damage to present seal and redo the lot.
Also being red it faded in the sun... but mate tested a patch with G3 and sofar has come up a treat now to wait and see if it lasts.
Interiour sound and as full leather. Will be easy to clean and get upto scratch...
Daz
Re: work has begun
Postby Bernard » Tue May 31, 2016 8:56 pm
Put up some pics as you make progress, it'll be a good one to follow.
Re: work has begun
Postby Daz » Wed Jun 01, 2016 12:51 pm
Bernard wrote:Put up some pics as you make progress, it'll be a good one to follow.
Will try to but i'm quite crap with techno stuff... i'm better with a spanner in my hand, my mate is at mine this afternoon i'm on 12 hours so i'm sure he'll have more done by time i get home. :D
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 5:55 pm
Got home and mate just finishing up for the day. Started refitting body panels after, he's happy the drop rails are ok just the rear end plates with rubber bung rusted and to be cut out and new plates welded in. But thinks hes found a tiny patch of surface rust, somewhere in the middle of the underside. But untill i get under there next sunday (day off!!) With wire brush attachment and clean the whole underside we won't know its extent.
He's fitted the body panels again as hes trying different cutting compounds to bring up the paint work from sun fade, and try it on metal and the plastic panels to check to see any difference you can see from various pics the sun fade and restore attemps, so far the G3 compound looks to be doing the best that is ofcourse if i manage to get the pics up.
First pic attempt... [img][IMG]http://i63.tinypic.com/9pul49.jpg[/img][/img]
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 5:58 pm
Dont think the pic upload worked can someone tell me what i did wrong so i can repost and do the others too.
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 9:46 pm
Next attempt to get a pic up
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 9:47 pm
Wohoo figured it out ok more pics to follow
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 9:49 pm
Ok i didn't figure it out it cropped the pic it was ment to show whole side of it???
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 10:07 pm
Ok lets try again
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 10:18 pm
Thats better, don't mind barrier just there to deter the kids from trying to get in it or under it
Front bumper to go back on and side skirts to be finished off
Rear re-assembled
The worst bit of rust in rear wheel well, which will be cut out and a plate welded in
The rusty brakes and damaged arch liner that needs replacing if i can get one!!
But the new brake bits to go in
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 10:32 pm
Interiour will just need a valet
One compound comparison
And another
G3 on end of boot and spoiler compared to top of boot not treated.
Whole of car was faded like this
Daz
Re: work has begun
Postby Daz » Wed Jun 01, 2016 10:35 pm
Is there a thread on here on how to repair the headlights. If i recall correctly it involved wet'n'dry and brasso but full details would be nice...anyone know the link???
Daz
Re: work has begun
Postby Bernard » Wed Jun 01, 2016 11:42 pm
There's a few threads...
viewtopic.php?f=11&t=1840
viewtopic.php?f=1&t=14857
http://www.myfto.co.uk/peeling.htm
I've had some good results just using a rotary polisher and some different grade compounds, if your friend has the gear it might be the easiest way to go.
Re: work has begun
Postby Daz » Thu Jun 02, 2016 4:56 am
Cheers Bernard
Read thur what links worked then ordered this
Lets see if it works.
Daz
Re: work has begun
Postby Daz » Thu Jun 02, 2016 6:08 am
Couldn't sleep last night know i'll pay for it in work today as i sit in the canny with a coffee gearing up to face the day... so went on amazon and went a bit nuts last night along with the light repair kit i also bought
This for protection afterwards
And to protect bodywork
Then to clean the underside and engine bay
And to degrease afterwards
In prep for chemical treatment
And to finish of a couple of tins of this
Daz
Re: work has begun
Postby brccrx » Fri Jun 03, 2016 6:32 pm
Red colour loves fading :roll:
Mine isnt as bad but still looks terrible :r
brccrx
FTO is my new religion
Re: work has begun
Postby Daz » Fri Jun 03, 2016 9:18 pm
brccrx wrote:Red colour loves fading :roll:
That it does
Daz
Re: work has begun
Postby Daz » Fri Jun 03, 2016 9:20 pm
Well everything bar the headlight restoration kit has arrived a few busy weeks ahead of me :D
Daz
Re: work has begun
Postby Daz » Sat Jun 04, 2016 11:56 am
Headlight kit arrive this morning will do before and after pics when i get round to doing it
Daz
