set of front wipers, not used - 10e plus two freebies: Rubber boot dampers (set of two) and Fabric interior seat cover set, in presumably good condition
Decat pipe with seal and 3 bolts - GONE to Gino
3G drilled and grooved rear brake discs (pair), used (machined recently, with perfect surface), plus a set of Green Stuff brake pads that were used with the discs - GONE to Gino
Manual Jack - GONE to Gino
manual gear stick gaiter - GONE to Chris
Center console (no cracks) - GONE to Chris
If you need to contact me, here's the number:
0851209623, Bart.
If this thread is up it means all the stuff is still for sale (I will update this post as situation changes). If you have any questions, fire away. Thank you.
