central locking
central locking
Postby paul2508 » Mon Sep 10, 2007 8:54 pm
when i press the central locking button the drivers door wont respond even though you can see thelock on the door tryin to move. is this a minor thing?
paul2508
FTO-Ireland rules my world
Postby Sebastian » Mon Sep 10, 2007 9:29 pm
it's a common thing .
if you look around the forum there is a solution ... :roll:
must do it miself as well
Postby stevec » Mon Sep 10, 2007 10:07 pm
Happened to me on a previous car (not FTO).
I took apart the mec. and found it clogged with old hardened grease. Cleaned it and lubricated all the sliders etc with silicon grease - right as rain after.
stevec
Re: central locking
Postby Myfeckin FTO » Mon Sep 10, 2007 10:48 pm
paul2508 wrote:when i press the central locking button the drivers door wont respond even though you can see thelock on the door tryin to move. is this a minor thing?
As it tries to move give it a little help yourself - continue to do this untill it can do it on its own accord - its just a little lazy - but it will free up ok.
Re: central locking
Postby paul2508 » Thu Sep 13, 2007 6:03 pm
ta da ....fixed, jus grabbed the latch on the door and shook it left to right a couple of times and now it works
paul2508
Postby ikeane » Fri Sep 14, 2007 10:45 am
I find this happening with my passenger door as well. It normally comes right itself but will start screwing up again after a while. Must have a go at opening it.
ikeane
Postby Muad_dib77 » Fri Sep 14, 2007 10:55 am
I'm guessing wd40 will do it a world of good if you want to "treat it"..
