by mark » Sun Mar 02, 2008 7:20 pm
any of you lads get any warning lights up on the dash. My alt went a few years ago and you could actually hear it dying (dronning sound with the battery light fading in and out on dash). I still managed to drive it around for a week or so before getting it fixed without the battery dying.
If its the alternator then get a new one, not even a factory recon. It's a lot of work to take it out and you don't need the extra hassle if it goes a month later! Also the GR alt differs from the the GPX in fitments and also from a 1.8 I think. Run a search from a couple of years ago as my GR got a new one and I posted the part number. Some also have different mountings and it's difficult to tell until you have them in your hand.
I popped the drive shaft out and half the suspension to get at it. Be wary of people saying stuff like it's just the engine mounts that need to be un done as these would get a lot of stress with the angles needed to pull out the alternator with the engine being jacked up. It's not a difficult job just a bit of work. Be mindful of gear box oil leaking (due to drive shaft removal) so it's a good time to change that too, can't do any harm!
good luck
