Caliper rattle (driver side)
Postby crayzidane » Tue Mar 03, 2009 4:17 pm
I have GPX brakes and recently its began to make a rattle noise,
took the wheel off and the caliper is loose in the bracket and rocking up and down.
The noise goes away when i use the brake.
I was just wondering if i need a new:
1)Caliper
2)Mounting Bracket
3)Both
Thanks D.
I'd rather be hated for what I am,
than loved for what Im not.
crayzidane
Postby colm_mcm » Tue Mar 03, 2009 4:33 pm
have you tightened the bolts? is there any obvious damage?
Postby crayzidane » Tue Mar 03, 2009 4:40 pm
Yea bolts are tight, no sign of damage, it seems like its rattling on the two long bolts/pins
crayzidane
Postby gary d » Tue Mar 03, 2009 5:13 pm
sounds like your slider bolts mate. camskill do caliper refurb kits slider bolts, seals etc
gary d
Postby gary d » Tue Mar 03, 2009 5:15 pm
just another thought have you checked the condition of your wheel bearings? :)
gary d
Postby crayzidane » Tue Mar 03, 2009 8:19 pm
Bearings seem fine, called into paul and he said I need new caliper and carrier, and if anyone has a gpx caliper PMme
crayzidane
Postby gary d » Tue Mar 03, 2009 8:25 pm
your caliper must be in be in pretty poor condition to justify replacing it and carrier, did paul give you any clue as to how this may have happened? If you dont have any luck turning up a second hand one, I think camskill carry theese also. happy hunting.
gary d
