Well a small update is due...
Bypass valve is working a treat, the valve/sensor issue has been fixed too. They came across another problem which was the belt was slipping at the higher rev range, this also accounted for the drop in boost.
A new belt was purchased, but two new smaller pulleys were installed as well to prevent any slippage.
They did a dyno run the very first day and it produced 304bhp (they did say that it would be about 10% less than Westwards which produced 333bhp)
They changed the belts and valve etc and it produced 360bhp, this was before the additional pulleys went in which have reduced any further slippage, they are going to run another power run on the dyno and expect 380bhp as it's now boosting all the way to the rev limiter...
So Utec will be going in today or tomorrow and will be remapped, so should easily see the 400bhp region!!
Updates will follow later in the week, hoping to have it back Wednesday or Thursday!
