colm_mcm wrote:changeover element pointless, already at optimum point. only use would be removing limiter, which can be done way cheaper.
StewyD32 wrote:really.. how... might be worth a separate thread
cullen5998 wrote:if i had the controller and i set it to kick in at 4000rpm why would the performance not be increased
eamop wrote:so would a mivec controller give a quicker 0-60 but slower speed increase after
Uncle B wrote:No mean to hijack but would it be pointless getting an emanage piggyback and a bigger set of injectors if you could get the lot for around €250 mark?
I suppose theres the dyno/mapping/tuning expense to consider also... for a max gain of what? 15BHP?
Obviously would make more sense for forced induction
MfFTO wrote:There is power to be gained from going down the NA route with a piggyback ecu + larger injectors + larger fuel pump (walbro) + fuel pressure regulator + colder plugs (denso) + decat exhaust and a good map. Its expensive chasing NA power for the relevant gains but you'd end up with a more reliable car than if you went forced induction IMHO - esp on the mivec.
However if you went this route and still wanted more power at least you'd have set your engine up better (with the increase in fueling) for going down the FI route.
If you really want considerably more power in your FTO though - an EVO or VR4 transplant is your only man.
