drink , it destroys lifes
Use this forum to discuss anything and everything non-FTO related
Postby cm75 » Tue Dec 23, 2008 11:08 pm
:oops: its all came to a head, i am an alcoholic.....last few mths i have been hittin it hard,,,,works went down hill , finances ?-none exisistant . totalling 90 quid a week. fell out with her and flung out ...
reality check. its time to give it a buy before i either am homeless permantely and jobless or i die.....
cm75
Postby Grace » Wed Dec 24, 2008 1:48 am
I really hope you can get yourself sorted Chris, if not for you, do it for your daughter.
Grace
Postby Sebastian » Wed Dec 24, 2008 1:56 am
heads up and dont let it get you . hard times everywhere but you have to be strong . think about those around you !
Postby Myfeckin FTO » Wed Dec 24, 2008 2:21 am
Sounds like you are still hitting it hard.
Its not going to be easy - but it has to stop.
You just get the one shot at life - don't f*** it up.
Postby Dragonheart » Wed Dec 24, 2008 4:55 pm
Often one of the hardest part to solving any probllem is finding the cause of it, you've done that bit so really make the effort give it up. It'll be worth it.
Postby mcgon1979 » Fri Dec 26, 2008 10:28 pm
thoughts with you cm75, I respect you being able to even state that its a problem and it has to stop. I hope you get the support from those around you to help you though it mate. good luck.
Ma olen kaine!
mcgon1979
Postby cm75 » Sat Jan 03, 2009 12:43 pm
:oops: cheers for the support . been behaving a little . i have managed to cut it back .but the true test begins on mon . when i return to work . coming home and not havin those few beers to un wind..good point . i finally finished my living room :lol:
cm75
Postby Muad_dib77 » Sat Jan 03, 2009 2:56 pm
I know this sounds like a bag o'sh..e but..
brew yourself a BIG pot of tea...finish it off on your own, if somebody else want's a cuppa brew another pot.
Once you've got 5-6 mugs of tea in you - you defo wont fancy a beer.
Alocohol can be a b.stard to get out of your life - but it'll be worth it.
Postby cm75 » Sat Jan 03, 2009 3:26 pm
cheers mate . i willl try that.....
cm75
Postby TopCat » Sun Jan 04, 2009 3:04 pm
I really do hope this works out for you mate, I've seen drink distroy a few lives. The fact that you can say it out in the open is a huge step. Ususally is stays behind doors, and can be hidden surprisingly well, but this normally just leads to it getting worse. I hope you find that there is support out there when you're able to admit you need help.
And don't look back! :)
TopCat
Return to Off Topic
