Page 1 of 1
Meath Newbie
Posted:
Sun Jun 29, 2014 7:30 pm
by gazmcg89
Hello all Gary here new to Fto's but no stranger to Mitsubishi's have had quite a few
Picked up a tip Fto earlier for a run around good runner not the prettiest but does the job
Also have a long term Mirage project with Gsr engine
Have had a few mivecs in the past too
Re: Meath Newbie
Posted:
Mon Jun 30, 2014 10:05 am
by Sebastian
happy posting
is it a Mivec?
Re: Meath Newbie
Posted:
Mon Jun 30, 2014 11:41 am
by gazmcg89
No its not its just the 2litre v6 which doesnt really bother me tbh . As a run around its perfect comfortable auto not bad on petrol and cheap to buy what more do you want
Re: Meath Newbie
Posted:
Mon Jun 30, 2014 1:26 pm
by StewyD32
Re: Meath Newbie
Posted:
Mon Jun 30, 2014 7:38 pm
by Mick ah
Welcome to the club.
I hope she keeps running well for you!
Re: Meath Newbie
Posted:
Mon Jun 30, 2014 8:32 pm
by gazmcg89
Cheers Mick gentleman to deal with
Re: Meath Newbie
Posted:
Tue Jul 01, 2014 1:37 am
by goz_83
Welcome to the club. If you need any help, feel free to ask. That's a fine fto you have. If you need parts, such as a drivers door, you can ask myself, or Gerry who have the bits and are near you. Gerry has a black one, so might be your best bet.
Re: Meath Newbie
Posted:
Tue Jul 01, 2014 2:45 pm
by gazmcg89
Re: Meath Newbie
Posted:
Tue Jul 01, 2014 5:22 pm
by Kace
Looks like Mongoose to me. I have the same.
Re: Meath Newbie
Posted:
Tue Jul 01, 2014 5:37 pm
by gazmcg89
It says blueflame on the top of the tips
Re: Meath Newbie
Posted:
Wed Jul 02, 2014 12:08 pm
by gazmcg89
Never mind saw it listed on camskill . Its a bluefame exhaust alright
http://www.camskill.co.uk/m3b0s11p465/C ... pipe_-_FTO
Re: Meath Newbie
Posted:
Fri Jul 04, 2014 1:04 pm
by brccrx
Welcome to FTO Ireland Gary, what happen to Gsr Asti You had a while back?
Re: Meath Newbie
Posted:
Fri Jul 04, 2014 1:55 pm
by gazmcg89
Still have it Seb it sat up for about a year and a half while I was away the clutch springs did not appreciate it too much now needs a clutch so will be done soon .
Re: Meath Newbie
Posted:
Thu Jul 10, 2014 12:53 am
by brccrx
Maybe the clutch slave cylinder give trouble?
Re: Meath Newbie
Posted:
Thu Jul 10, 2014 5:07 pm
by gazmcg89
Its funny you say that Seb because the slave through out its Piston but after it was put back together the clutch would not engage what so ever tried bleeding etc . Its a sh1te set up on the gearbox the way the slave is set up anyway its not where it wants to sit naturally at all the holes that were tapped are a good bit off . I have a 1.3 box with Mivec lsd there that will be fitted when i manage to drop the box and inspect
Re: Meath Newbie
Posted:
Thu Jul 10, 2014 5:16 pm
by mivecrx
gazmcg89 wrote:Its funny you say that Seb because the slave through out its Piston but after it was put back together the clutch would not engage what so ever tried bleeding etc . Its a sh1te set up on the gearbox the way the slave is set up anyway its not where it wants to sit naturally at all the holes that were tapped are a good bit off . I have a 1.3 box with Mivec lsd there that will be fitted when i manage to drop the box and inspect
The slave never bleeds right as it's facing down and the air gets trapped, try using a vacuum breeder or even an oil sucker will work. Where the two bolts are holding it down put some washers or a nut under the slave cylinder to rise it, especially the one on the arm side. I made a longer slave arm for mine just to make sure it was pushing the fork far enough.
What clutch are u using?
Re: Meath Newbie
Posted:
Thu Jul 10, 2014 6:58 pm
by gazmcg89
Its a Mivec clutch in it afaik . Seb did the work for the last owner and knows better exactly whats in there . Yeah i thought about using a washer but they have tapped across into what looks like the 1.3 slave mounting points on the side if that makes sense cant see that lasting long term ? the slave was bleeding maybe not properly but surely some sort of pedal would have returned if it was something so simple ?
Re: Meath Newbie
Posted:
Thu Jul 10, 2014 11:12 pm
by brccrx
Its Rs clutch Gary, this should outlast organic Exedy
I had this problem with Dave varsion R a few days ago when after engine conversion. It seemed ftucked slave cylinder as we flushed the whole system, it turned out the fluid Dave brought with him was containing water and when we used my fluid and flushed the system again bang the clutch works grand!
Re: Meath Newbie
Posted:
Thu Jul 10, 2014 11:23 pm
by mivecrx
gazmcg89 wrote:Its a Mivec clutch in it afaik . Seb did the work for the last owner and knows better exactly whats in there . Yeah i thought about using a washer but they have tapped across into what looks like the 1.3 slave mounting points on the side if that makes sense cant see that lasting long term ? the slave was bleeding maybe not properly but surely some sort of pedal would have returned if it was something so simple ?
I know what you mean, I tapped down threw the original holes for the slave cylinder, they go into box horizontal and the new ones are going threw them vertically. If the thread is good it will hold no problem, if not get a longer bolt and put a nut underneath if it fits.
If your getting a new clutch get Exedy, I've a 3puk in mine and its's serious. My mate has been using an Exedy organic for 2year and it's still working well.
As for for having no pedal at all, that could well be the slave cylinder or air. If you don't have any tool for bleeding then undo the cylinder and bolt it back into the standard position( you will have to leave turbo pipe off). Bleed it the two person way and see if you get a pedal back.
Re: Meath Newbie
Posted:
Fri Jul 11, 2014 12:11 am
by gazmcg89
Have tried 2man bleed already mate . I just cannot see it being a slave problem it is operating as normal after being put back together . The clutch fork looks like its sitting miles away from where it should normally to me anyway . I got absolutely no resistance in the pedal while bleeding . The clutch is stuck as if the pedal is pressed
