Firstly, I'll go through what tools I needed:
Vice Grip
Selection of sockets and spanners, mainly 21mm, 17mm and 14mm.
Axle stand
Jack
Allen keys.
Hammer
WD40
The first job was to remove the strut brace, I removed the centre bar first, using a 17mm spanner and allen key
Next, I loosened the centre nut in both of the front suspensions (17mm again)
Loosened the wheel nuts a little while the wheels were still on the ground.
Jacked up the front of the car and sat it on axle stands.
Removed the front wheel
Sprayed the droplink and bolts on bottom of the suspension strut with WD40
Removing the droplinks
Type 1, allen key & spanner
once WD40 has soaked in, hold the threaded section still with the allen key, and turn the nut counter-clockwise to remove the droplink. supporting and adjusting the wishbone with a jack will make your life easier.
Type 2, 2 spanners
Using as thick a spanner as possible, hold the threaded section in place using a 14mm spanner near the joint, use another 14mm spanner to remove the nut and then the droplink.
Removing the suspension unit
With the wishbone supported underneath by the jack, I then removed the 2 nuts and bolts that attach the suspension and hub assemblies. straightforward enough.
detached the 2 assemblies taking care not to damage the brake hoses.
Then it was a matter of unbolting the 3 nuts under the bonnet and dropping the unit out.
