i think that is a load of boll*x.
dont waste your hard earned
How does it work?
It will modify any standard ECU by telling the ECU that the incoming air in the intake system is cold and so advances the ignition to compensate producing more power. In many cases fuel economy is increased too. Power is increased by up to 15BHP and torque is increased significantly.
It will be more responsive and you WILL LIKE IT.
What difference can you expect?
Increased acceleration at low end revs
Higher top end speed
Faster 0-60 and 1/4 mile times
Quicker throttle response
Smooth out flat-spots
Can increase MPG
soc wrote:there's a reason remaps are expensive and that's because of the research and development work that goes into them
