Car is handling very sweetly now with the postive camber bushes fitted. Feels much more solid and direct on the road and quite a few annoying noises are now gone. I dunno if there is much difference over a car without the positive castor bushes cause I suspect mine were well worn (although Paul did say they weren't that bad). Either way the car is handling sweet and I'm loving every single corner
I was gonna get the camber bolts and an alignment done this saturday but Paul reckoned he might need to play with the settings on the track rod arm when fitting the new steering rack gaiters as there is a very slight pull to the left - so he suggested getting this done first and then getting the camber bolts and alignment done.
On the timing belt front - it sounds like I was a lucky, luck boy...... Paul said the one he took off was in ribbons and had a crack down the centre line. Phew...... glad I got it changed.
So to celebrate I just ordered 2 front and rear strut braces from Camskill - £139 all in..... happy days! At the risk of getting a slagging/bo****ing from CJ I'm starting to think about holding onto this bloody car for a while longer
