History
I've owned this car for the past 6 years, I purchased it from an FTO enthusaist back in 2002. Some of you may have met the previous owner (Rob), he was fanatical about FTOs and looked after this car extremely well. I've carried this tradition on over the years, not a penny has been spared to ensure the car has been running / looking its best at all times.
In the past 6 years, I've done 52,000 kms i.e. less than 9000 kms per year. I've major service history going back to 58,000kms. In terms of general servicing (oil, filters, ATF, brakes, droplinks, ARB bushes etc), I've attended to this myself during the term of ownership. I've changed the engine oil and filter every 7k kms, the ATF and filter has been changed every 10k kms on average.
Any time I've required significant mechanical work undertaken, the car has always been left out to Paul Nolan in Artane. The most recent visit during the first week of February entailed the following:
Cam seals replaced (big job and not cheap)
Cam belt replaced
Tappets adjusted
Engine oil \ filter change
ATF Gearbox oil \ filter change
Full mechanical check
Paul ran the car himself for a day to ensure the cam seal replacement had taken properly, he commented that my GPX was one of the best FTOs he had come across both in terms of mechanical health and overall condition. If you're interested in the car and want a reference, Paul (086 2649884) is more than happy to back up his comments if required.
Heres the full spec:
The Car
1994 Mitsubishi FTO GPX Tiptronic, standard GPX spec, steel silver, 170k kms (105k miles), NCT 12/09. Tax, 04/08
Engine
2.0L 6A12 MIVEC, ITG induction kit, Denso Iridium long-life spark plugs (installed 155k kms). Full catback Mongoose twin exit exhaust with cat bypass pipe. Engine is running perfectly and never misses a beat.
Milestones: Cambelt change 131k kms / 170k kms, ancillary belt change 131k kms / 155k kms, fuel filter, 155k kms, stepper model replaced 155k kms, coolant change and rocker cover gasket replaced 141k kms. Engine oil (Castrol GTX Magnetec 10W40) and filter changed every 7k kms.
Electrical
Starter model fully rebuilt @ 170k kms (Jan '08 )
Alternator rectifier pack replaced approx 3 years ago.
New high load battery installed Nov '08.
Transmission
4-speed tiptronic box, shifts very smoothly in either tiptronic mode or Drive. ATF and filter changed at least every 10k kms. Gearbox input, output and speed sensors replaced in May 2006.
Suspension
Suspension lowered on Apex springs.
Complete suspension refit in November 2004, items replaced include:
All 4 dampers/shocks (KYB)
Front bottom arm rear bush (extra castor)
Front ARB bushes
Rear ARB bushes
Rear outer bottom arm bushes
Rear inner bottom arm bushes
Rear camber bolts
Rear outer lower arm bolts
More info here:
http://www.fto-ireland.com/forum/phpBB2 ... php?t=1489
Front (142k kms) and rear (130k kms) droplinks changed.
Front and rear strut braces.
You'll find it very difficult to find another FTO to match this car in the handling stakes, the suspension setup is perfect for fast road action and cornering.
Brakes
Standard GPX front and rear disks. The car originally had Black Diamond fron disks installed but I removed them a few years ago due to wear in favour a new set of Mitsi OEM disks.
Pads Front: EBC Greenstuff
Rear pads: standard Mitsi pads
Brake fluid flush and change (DOT4) 136k kms
Calipers painted silver
Wheels and Tyres
17" AEZ Icon wheels (I've 2 spare AEZ wheels - included in the sale), Vredestein Ultrac (215/45/17) tyres. The Ultracs are an excellent tyre and equal Goodyear Eagle F1s for grip (wet and dry) with the benefit of reduced road noise and longer life. The tyres have 14k kms on them with very little wear. Wheel nuts replaced with new shiny ones recently, lock nuts on all wheels.
Exterior
Paintwork in excellent condition, Version R spolier, facelift conversion with clear fog and indicator pods, clear side repeaters.
Interior
Full (real) Leather retrim in black / grey, FTO logo stitched into headrests, centre console, gear shift and instrument binncale sprayed steel silver as per exterior, CF gear shift knob, alu handbrake cover with leather shroud, KMC v.3 white dials with alu dial rings, alu needle cups and CF rear instrument surround, Momo steering Wheel flare replaced with fire extinguisher, alu pedals and footrest.
ICE
JVC KD-SH55R CD reciever
JVC 12 disk CD changer
Rockford Fosgate Punch 400W RMS 4-channel amp
Sony XM-502X 2 channel amp (130W bridged for sub)
Rockford Fosgate componants up front (50W RMS per channel)
JBL 6x9s (50W RMS per channel)
8" sub in homemade enclosure
1.2 Farad Powerflow capacitor
Boot, quarter panels, parcel shelf and doors fully soundproofed
Thats about it, if you've any questions or want to organise a viewing give me a shout. No timewasters!
Price: 6750 euro
Contact: ciaran @ fto-ireland.com, PM or 087 22 07792
Pictures Below
