Presuming yours isn't a facelift model...
They're standard push-in 12V 5W bulbs. same as the number plate and side indicator lights.
the only potential problem I can see is getting the screw that holds the light cluster off. these can get stuck quite easily, so use the correct size screwdriver to avoid rounding off the screw head.
like this, only clear:
