vr4 engine in fto
vr4 engine in fto
Postby dwayne21 » Thu Sep 15, 2005 1:31 am
Does anyone have any links or any information on how to do the vr4 engine in fto properly. I want to single turbo it. I have all i need to get things going i just want to see how it fits and what other fto owners that have done this conversion have done.I have a gear box not a transmission so i have more room to deal with.
dwayne21
Unleaded
Unleaded
Postby kevinod » Thu Sep 15, 2005 3:25 am
Not sure what you mean by vr4, do you mean put a different engine into the FTO?
For turbo, there's a couple of docs in the downloads page that would probably be worth looking at?
hth
Postby paullen » Thu Sep 15, 2005 8:34 am
Speak to Richard on the UK FTOOC. Hes done the swap. I think it was very costly and time consuming, but he does have the fastest, most powerful FTO in the country :D
He can secound at ten of the best in the front wheel drive class!
1997 FTO GX Aero
Brembos, Custom Induction kit, Toad alarm, front and rear strut braces, Halo fogs, EL dials, EVO enkeis, lowered, Apexi N1 exhuast, denso iridium plugs, battery in the boot, clear repeaters...need I go on?
www.all-torque.co.uk
paullen
Unleaded
Unleaded
Postby Myfeckin FTO » Thu Sep 15, 2005 9:30 am
Saw the article in one of the Jap magazines on RichardB's VR4 engined car - but it looked like quite an awkward conversion to do - he even had to make a bow in the back wall of the engine bay to make the engine fit.
Nice job in the end but I bet it cost him an arm and a leg - you should also check other options like putting an EVO engine in there. In fact there is an EVO engined FTO for sale in the UK at the mo - this would be a far cheaper route to take.
Postby dwayne21 » Thu Sep 15, 2005 4:18 pm
I have already bought the engine and whats not just need some advice how to get at it.
dwayne21
Unleaded
Unleaded
Postby Myfeckin FTO » Thu Sep 15, 2005 4:20 pm
dwayne21 wrote:I have already bought the engine and whats not just need some advice how to get at it.
You absolutely must speak with Richard B - try PM'ing him on the UK site.
Postby dwayne21 » Thu Sep 15, 2005 4:22 pm
Are there any posts with that set up on this chat.The other fto check is down right now.
dwayne21
Unleaded
Unleaded
Postby Myfeckin FTO » Thu Sep 15, 2005 4:28 pm
dwayne21 wrote:Are there any posts with that set up on this chat.The other fto check is down right now.
You could try his website - http://www.mitsubishi-fto.net/main.htm
May be able to contact him through this.
That is some machine he has - fair deuce for taking this upon yourself.
If I were you I'd be buying a swear jar round about now. :lol:
Postby dwayne21 » Thu Sep 15, 2005 4:54 pm
I want to run the vehicle single turbo as well.
dwayne21
Unleaded
Unleaded
Postby Myfeckin FTO » Thu Sep 15, 2005 5:03 pm
dwayne21 wrote:I want to run the vehicle single turbo as well.
You won't be using the VR4 turbos then - What size single turbo do you intend to run with?
Postby dwayne21 » Thu Sep 15, 2005 5:05 pm
Usin one t4 turbo AR 60 FRONT END AR 1 BACK END. Relatively big turbo.
dwayne21
Unleaded
Unleaded
Postby Myfeckin FTO » Thu Sep 15, 2005 5:31 pm
dwayne21 wrote:Usin one t4 turbo AR 60 FRONT END AR 1 BACK END. Relatively big turbo.
Good size turbo - are you buying the full kit inc intercooler etc?
Would be very interested in hearing more about this project as it happens.
What power are you hoping for? - By the sounds of it you will have 350BHP + if set up right.
Postby dwayne21 » Fri Sep 16, 2005 12:59 am
Well i plan to run low boost for a good bit.
dwayne21
Unleaded
Unleaded
Postby Daz » Fri Sep 16, 2005 5:17 pm
Myfeckin FTO wrote:Nice job in the end but I bet it cost him an arm and a leg - you should also check other options like putting an EVO engine in there. In fact there is an EVO engined FTO for sale in the UK at the mo - this would be a far cheaper route to take.
yep it did cost him a lot also alot of time close on 18 months if i remember right. as he did most of the work himself on his time off.
Daz...
Daz
Postby dwayne21 » Fri Sep 16, 2005 8:32 pm
I am looking to set up in two weeks.Just once i can get turbos cleared fire wall then np.I hoping for two week set up
dwayne21
Unleaded
Unleaded
Postby kevinod » Fri Sep 16, 2005 9:03 pm
dwayne21 wrote:I am looking to set up in two weeks.Just once i can get turbos cleared fire wall then np.I hoping for two week set up
I'm sure you know an awful lot more about it than I do, but 2 weeks to fit a new engine into a car is a bit of an ask, even if you're taking the time off to do it so you've all day & night to work on it.
Best of luck though, keep us updated, would be interested to see how it goes!
I have a friend who put a 323 GT (or something like that, can't think of the exact model) turbo engine into his MX3, took him a long time, and even then he discovered he couldn't close the bonnet, had to get a bulge put into it for the turbo. He was doing it in his spare time, weekends etc. but even still... I'm sure he still has wires around his engine he doesn't know what to do with! :lol:
Postby dwayne21 » Fri Sep 16, 2005 9:11 pm
Yeh i know but a friend of mine here has an orginal vr4 so i am using his car as a base. Also we took certain things in consideration.We will leave it twin turbo.
dwayne21
Unleaded
Unleaded
Postby CJ » Sat Sep 17, 2005 4:34 pm
I'll be watching this development with a lot of interest, its a serious bit of work and I imagine it won't be easy. That said, you obviously have experience in this area so I hope it goes to plan. Make sure and keep us updated.
Postby dwayne21 » Sat Sep 17, 2005 10:10 pm
Yes i will my friend.
dwayne21
Unleaded
Unleaded
Postby JJ » Sun Oct 02, 2005 5:35 pm
I saw Richards car at our nnual meet end of September and it does fly. I seem to remember his was up for sale. I think he's starting another project as I keep seeing him bidding on FTO's on ebay
JJ
Postby dwayne21 » Sun Oct 02, 2005 5:42 pm
Well i have lifted in the vr4 engine now.I got it in wired up computer in gear box on and every thing in 8 hours.It was 5 guys working at the same time.I have to finish wire up put on suspension i have to get a solid back engine mount built and hook up intercooler,blow off valve now. I also have to put in radiator and ac parts.
When that stuff is all finish i can now deal with heat wrapping and building a couple heat shields, sorting out exhaust stuff whats not.I have a question my engine didn;t come with down pipes does anyone upgrade the size of the down pipes from each turbo and if they do to how much.Right now i have a 2.5 inch exhaust system until i get in my upgraded fuel pump,fuel pressure regulator, water injection and intercooler water as well as put in the management that i have home i will not upgrade this to 3 inch.
dwayne21
Unleaded
Unleaded
Postby JJ » Sun Oct 02, 2005 5:44 pm
dwayne21 wrote:Well i have lifted in the vr4 engine now.I got it in wired up computer in gear box on and every thing in 8 hours.It was 5 guys working at the same time.I have to finish wire up put on suspension i have to get a solid back engine mount built and hook up intercooler,blow off valve now. I also have to put in radiator and ac parts.
You sound as if you know what you're doing - a huge project to take on - I know it took Richard a long long time ... have you spoken with him about it? If not I'm sure he'd give you any help he can
JJ
Postby dwayne21 » Sun Oct 02, 2005 5:50 pm
I spoke to him about some decisions making stuff as well as to find out what can;t work and which can. I use the fto front right engine mount instead of the vr4 one it gave me more room to work with.The engine itself is a new engine.Everything is clean as can be.I plan to take a couple pictures of the set up as well as my car.My whole dash board is out it sort of depresses me but in the end i will be happy.I have to get some heat shielding material for my fire wall.Make sure that heat doesnt try to escape.We worked on the car yester from 10 in the morning straight till 8 in the night.
dwayne21
Unleaded
Unleaded
Postby JJ » Sun Oct 02, 2005 5:52 pm
dwayne21 wrote:I spoke to him about some decisions making stuff as well as to find out what can;t work and which can. I use the fto front right engine mount instead of the vr4 one it gave me more room to work with.The engine itself is a new engine.Everything is clean as can be.I plan to take a couple pictures of the set up as well as my car.My whole dash board is out it sort of depresses me but in the end i will be happy.I have to get some heat shielding material for my fire wall.Make sure that heat doesnt try to escape.We worked on the car yester from 10 in the morning straight till 8 in the night.
look forward to seeing the pics :D
JJ
Postby kevinod » Sun Oct 02, 2005 7:34 pm
Sounds like you made some great progress! Did you have any probs fitting the engine with the firewall?
Must seem like a lot of work left to do but keep at it, another few days like that and it'll be pretty close if not done.
Looking fwd to the pics myself!
Next
