Lights
Lights
Postby Dave » Mon May 09, 2005 11:04 am
Bought a set of blue tint lights there from one of the online there about two months ago. needed a small bit of fitting to get them in, but since then the lights have only being working intermitantly, most times i'd have to pop the bonnet and take the unit out and fiddle around with it until it worked. one has since blown!
any ideas??
oh, i had to take a small what piece of plastic out of the light fitting itself on the car for the new lights to fit!
was this the same for anyone else fitting the bluevision?
Dave
Postby Mustang » Mon May 09, 2005 11:18 am
Sounds like a loose connection. Either you've loosened one of the wires to the light socket, or the bulb is not sitting right, and you're loosing the connection.
NO! You bought the high beam bulbs and fitted then in the dipped beam sockets correct? If so you should have modified the connection on the bulb itself only! If you've modified the actual light housing on the car itself, I'd say thats where the problem lies.
With an intermittant connection it's quite possible that the bulb could blow.
Mustang
Re: Lights
Postby Myfeckin FTO » Mon May 09, 2005 11:20 am
Dave wrote:oh, i had to take a small what piece of plastic out of the light fitting itself on the car for the new lights to fit!
Can't really help with regard to the blown bulbs - but when I fitted the bluevision headlights to the FTO dims I had to cut off the plastic tab that runs along the top of the bulb unit to fit the light unit.
Sounds like you've fitted a different model of bulbs rather than the HB3 / HB4 combination on the FTO. Could this be a reason for your blown bulbs?
Postby Dave » Mon May 09, 2005 11:28 am
http://www.autobulbsdirect.co.uk/hb3-4_bulbs.htm#ib
these are the ones i bought. the connection shouldn't be loose really cos it's the bulb itself that i've to fiddle with, not the wires or anything like that.
i might just fork out for the phillips and get it over and done with!
Dave
Postby Dave » Mon May 09, 2005 12:29 pm
bit the bullet and just got a new set of phillips. side lights thrown in, so it's not all bad.
i needed one anyways seeing that one was gone! looked a bit mank with one blue and one yellow light!!
Dave
Postby CJ » Mon May 09, 2005 2:48 pm
Dave wrote:http://www.autobulbsdirect.co.uk/hb3-4_bulbs.htm#ib
You didn't buy the Osram HB3a's by any chance did you?
Postby Dave » Mon May 09, 2005 2:50 pm
no, the link might be wrong, but it's the ones above it!
Dave
Postby CJ » Mon May 09, 2005 2:54 pm
You don't mention if its HB3's or HB4's you have Dave...
Postby Dave » Mon May 09, 2005 3:02 pm
can't honestly remember, i still have the packaging at home, they were probably the low beam ones, HB4's i reckon! i put one old light back in as a means to an end and it works fine which rules out the loose connection theory!
Dave
