Reverse selection problems
Postby fto52c » Thu Dec 16, 2004 5:44 pm
I've always had problems getting the car in reverse, but have only recently been failing on a regular basis - so i've just started to deal with the problem, but could do with some advice.
I thought it was the locking mechanism getting stuck when i select 5th gear and not disengaging properly, however i've looked at it and it seems to be OK. My next thought is the synchro, but before i get in too deep does anyone have any specifics i should be checking?
Could it be as simple as changing the gearbox oil?
fto52c
Re: Reverse selection problems
Postby Myfeckin FTO » Thu Dec 16, 2004 7:25 pm
fto52c wrote:I've always had problems getting the car in reverse, but have only recently been failing on a regular basis - so i've just started to deal with the problem, but could do with some advice.
http://www.ftooc.org/phpbb/viewtopic.php?t=20846
V similar problem.
MfFTO
Postby CJ » Thu Dec 16, 2004 8:38 pm
V similar problem.
MfFTO
Indeed, I had this problem in the GS (also affected 5th gear), one of the clips on the end of one of the selectors was bent. Not a major job to fix IIRC.
