ftonewbie wrote:Hi
I want to put alloys and tyres on a standard GR auto...
I was thinking that 17's are the way forward from reading the other comments - as people seem to have had to alter the wheel arches etc when they went larger.
The sticker on the door advises 16's but they look a bit small and out of place.
Can someone advise me of the best wheel size / tyre ratio to get, avoiding any rubbing and unnecessary body work?
Thanks!
Welcome to the site! You might want to change your name though if you're planning on having the FTO for a while.
17's are an ideal size aftermarket rim - a good compromise between the small 16's and the too large 18's.
To keep to the stock diameter you will likely need a tyre profile such as a 215/40 R17 - though I ran 215/45 R17's for more comfort - that and they helped fill the arches better than the 40 profiles plus giving a more comfortable ride - I ran these on lowered Apex springs and uprated dampers and had the wheelarch liner riveted back as far as it would go. I wouldn't worry about a small bit of rubbing though - its only a plastic wheelarch liner and it would likely only happen at full lock unless your arch liner was very loose.
