whats wrong here
whats wrong here
Postby d_dan » Thu Sep 11, 2008 9:40 pm
Guys my window has been actuing up the past few days. When I put it up it goes up half way and back down (as if you had cought your finger in the window and it was releasing)
And now its stopped working all together.
Is this the motor or some sort of sensor etc.
Postby colm_mcm » Thu Sep 11, 2008 11:15 pm
Didn't think the FTO had anti-pinch on the windows.
try cleaning out where the glass slides up along the door, and look for any obstructions.
If your window has stopped working altogether it may be the window motor/regulator that's at fault. there may also be something blocking the glass. When you press the window button, are you hearing any clicking noises, or does the glass make any effort to move?
I have a motor and regulator if you need one.
Postby d_dan » Fri Sep 12, 2008 12:01 am
no it was just oin up half way and then commin back down 3 or 4 times and then goin u fully finally, and then at burger king drive through it just stopped when i was putting it down
