help please
Say hello to other forum members
Forum rules
Please familiarise yourself with the forum rules before posting!
help please
Postby april » Fri Sep 30, 2011 10:34 am
thanks all for your reply and hi people.the leak seams to stop when the engine is run,is just a fast drip when its happening,its on the drivers side just below the oil dip(behind)im not sure if its the engine with 2 belts attached ha a bit thick with cars lol
april
Re: help please
Postby StewyD32 » Fri Sep 30, 2011 4:20 pm
Hello to you too and :wel
Silver 97 Mirage Asti V coupe
Burgundy 95 GR
Silver 95 GPX
StewyD32
Full Throttle Owner!
Re: help please
Postby Sebastian » Fri Sep 30, 2011 6:01 pm
april wrote:my antifreeze is leaking from under car is this just a loose pipe
Is this a question ? an exclamation ? a conclusion ? or your way to say HI to people :?
Anyhow , worst case scenario is a broken water pump .. .
Re: help please
Postby optical illusion » Fri Sep 30, 2011 7:13 pm
Christ almighty.
Re: help please
Postby colm_mcm » Fri Sep 30, 2011 7:17 pm
Its not just water draining from the aircon is it? Where abouts is the water coming from? The aircon is on the passenger side, water pump on the right and radiator at the front.
Re: help please
Postby Dragonheart » Fri Sep 30, 2011 7:57 pm
Check that theres no component in the bay with any cracks in it. A leak could be caused by anything so only way to find out is by getting under the car and having a look.
Dragonheart
Re: help please
Postby threediamonds » Tue Oct 04, 2011 6:23 pm
optical illusion wrote:Christ almighty.
:smt005
If you are a 'bit thick with cars' then best to a mechanic to sort it out- in case its anything serious that needs fixing a.s.a.p
Dublin- Home of Guinness, Dáil Éireann and square wheels.
threediamonds
Return to Introduce yourself
