.colm_mcm wrote:where is the dent, and where are you?
steelroe wrote:The spray you talk about CJ does not go to low enough temp. CO2 will go down to almost -80.
Kace wrote:Ok - that sounds like a plan. Now - to find a 'cheap' small fire extinguisher !!
steelroe wrote:Remamber the dent has to be heated first, with a hair dryer or similar.
steelroe wrote:I will not work on every dent. If there is a crease in the dent it will not work. I have tried it 3-4 times with good sucess.
steelroe wrote:CJ di you see ice forming on the panel when you sprayed on the Freezer spray?
