macspratt wrote:Is there a neon bulb on the market also for the interior mirror,i think it would be kinda cool to have the interior light up blue when u lock the doors...
macspratt wrote:as for the headlight bulbs ,going to go with the philips blue vision just for the dip beam,going to leave the high beam as they arnt going to get used to much anyway.
As for the front fogs,what bulb wil i need for there??want to try and stick to the blue vision if pos.!!
macspratt wrote:Hi,,looks like these bulbs on ebay will be ok,going to order them today.
THANX GUYS.
AIDAN!!!!
KEEP UP THE GOOD WRK!!!!!!!
Hi,, think i have a slight problem,,there is no side light conversion on my car,the first turn on my colum brings on the the front fogs and second turn brings on my dips,click forward brings on high beam.Myfeckin FTO wrote:macspratt wrote:as for the headlight bulbs ,going to go with the philips blue vision just for the dip beam,going to leave the high beam as they arnt going to get used to much anyway.
9005 High Beam - HB3
9006 Low Beam - HB4 (or HB3 and cut plastic strip on bulb)
501 Sidelights - W5W
453 Front fog lamp - H3
I would recomend using all the same type of bulb - It will look crap if you have bluevision dims and normal sidelights or head lights - You'll have a nice crisp blue light beside a dirty yellow light and it won't look right.
macspratt wrote:...there is no side light conversion on my car,the first turn on my colum brings on the the front fogs and second turn brings on my dips,click forward brings on high beam.
macspratt wrote:Its a 95 gr,,everything is working as you described,but when i flick the fog switch it only puts on the rear fog,theres no change in the fromt indicator cluster at all.
Ive undone the screw in the lense but caunt seen to get the unit out.
Is it possible that i dont have front fogs??or do all GR s have front fogs??
have u any advise on how to remove the unit so i can have a closer look.
macspratt wrote:Back again,lol, managed to get out the unit"quite simple when you know how" anyway only found the two bulbs in there,the large indicator bulb on the left and the small bulb on the right looks like a W5W? its the same size as. but no signes of a seperate fog bulb or anywhere that one should go for that matter"strange hey"?!
macspratt wrote:Hey guys , just found some 36-39mm 9 led neon bulbs on ebay £5.89
macspratt wrote:yea,kace they look 100 times better than the stock ones ,,i went for the philips blue vision,from power bulbs.
http://www.powerbulbs.co.uk/
AIDAN,,
PASSION RED GR!!!!!!1
AIDAN,,
