Alarms
Alarms
Postby richardc9052 » Thu Feb 03, 2011 1:43 pm
Ok i have been doing a lot of routing aroung my fto the last few days and have found sensors for an alarm everywhere, including an interior proximity sensor... now i dont want to start ripping the interior apart to follow the wiring but i cannot for the life of me find the alarm itself.. i have a Falcon alarm keyfob but it doesnt seem to do anything. :(
So where are your alarms located normally? engine bay? under the dash?
Anyway im loving my fto :D
Cos they are "GORGEOUS" - StewyD32
richardc9052
Re: Alarms
Postby Mustang » Thu Feb 03, 2011 3:03 pm
First up -check/change the battery in the key fob. If there is a led on teh fob does it illuminate?I think the control units tend to be in the passanger or driver foot well or else the engine bay.
Mustang
Re: Alarms
Postby richardc9052 » Thu Feb 03, 2011 7:19 pm
yep it illuminates for all 3 buttons.. hmm i will look! thanks :P
richardc9052
Re: Alarms
Postby CJ » Thu Feb 03, 2011 8:32 pm
Check under both seats for the control unit, behind the carpet in the passenger footwell is a favorite location, as it the rear quarter panel.
Re: Alarms
Postby Muad_dib77 » Fri Feb 04, 2011 12:20 pm
Also there's a piece of trim in the drivers foot well below the steering wheel.. you wont be able to see up there so stick your hand in and have a poke about (sorry)..
keep in mind that the metal framework up there is a bit like razorblades..
Re: Alarms
Postby colm_mcm » Fri Feb 04, 2011 1:53 pm
Isn't that piece of trim just held in by clips?
Maybe different car I'm thinking of?
Re: Alarms
Postby Muad_dib77 » Fri Feb 04, 2011 3:44 pm
colm_mcm wrote:Isn't that piece of trim just held in by clips?
Pretty sure there's a screw or two in there... but then.. it's been so long that I could be thinking of a different car..I just remember getting cut to bejaysus when I installed my little el-dial dimmer yoke on that same panel..
Re: Alarms
Postby colm_mcm » Fri Feb 04, 2011 3:50 pm
The innards of the dash are def sharp alright.
Re: Alarms
Postby richardc9052 » Fri Feb 04, 2011 3:52 pm
colm_mcm wrote:The innards of the dash are def sharp alright.
Stab proof gloves needed then!
richardc9052
Re: Alarms
Postby richardc9052 » Sun Feb 06, 2011 5:54 pm
It looks like the actual unit has been removed as i couldnt find it..
I tried following the cables from the sensors but they are unplugged (as in there is a male connection at the end)
Why would someone remove an alarm?
richardc9052
Re: Alarms
Postby Muad_dib77 » Sun Feb 06, 2011 6:56 pm
Could've been faulty..
..or..
person was looking to resell the brain gubbins of the alarm, seems silly though as as far as I know the costly bit of an alrm these days is all the senors and a good install..
atleast now you know...
